Zum Hauptinhalt wechseln
Einleitung
Use this guide to bring life back to your iPhone 7 with a new battery. If your battery is swollen, take appropriate precautions.
This guide instructs you to completely detach the display assembly; this is intended to prevent damage to the display cables. If you feel comfortable removing the battery without putting undue strain on the display cables, you can skip the steps for disconnecting the display.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Einführungsvideo
  1. Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. Attach a suction cup to the lower half of the display assembly, just above the home button. Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  4. Pull up on the suction cup to create a small gap between the display assembly and the rear case. Insert the flat end of a spudger into the gap. The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. Slide the spudger to the left along the lower edge of the iPhone. Twist the spudger to widen the gap between the display and rear case. Twist the spudger to widen the gap between the display and rear case.
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch. Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display. Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. Insert the flat edge of a spudger into the bottom right corner of the device. Twist the spudger to widen the gap between the display assembly and the rear case. Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
  8. Pull up on the suction cup to lift up the display and open the iPhone. Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. Pull up on the small nub on the suction cup to remove it from the front panel.
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place. Be careful not to damage the plastic clips on the top edge of the phone.
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. Android Fix Kits
    A new screen or battery is one kit away.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  12. Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case. Open the iPhone by swinging the display up from the left side, like the back cover of a book. Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
    • Three 1.2 mm screws
    • One 2.4 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  13. Remove the lower connector bracket.
    • Remove the lower connector bracket.
  14. Use the point of a spudger to lift the battery connector out of its socket on the logic board. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone.
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  15. Make sure the battery is disconnected before you disconnect or reconnect the cables in this step. Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board. To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  16. Remove the two 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector. Remove the bracket. Remove the bracket.
    • Remove the two 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
    • Remove the bracket.
  17. Disconnect the front panel sensor assembly connector from its socket on the logic board. This press connector should also be reconnected one end at a time to minimize the risk of bending.
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  18. Remove the display assembly.
  19. Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
  20. Remove the vent. Remove the vent.
    • Remove the vent.
  21. Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board. Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  22. Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
  23. Remove the Taptic Engine. Remove the Taptic Engine.
    • Remove the Taptic Engine.
  24. Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery. Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery. Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
    • Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
  25. Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery. Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
    • Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
  26. If this is your first time removing an iPhone battery adhesive strip, refer to the video in the following step before beginning. Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly. Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • If this is your first time removing an iPhone battery adhesive strip, refer to the video in the following step before beginning.
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
    • Repeat the previous step for the second strip.
    • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
    • If you removed both adhesive strips successfully, skip the next step.
    • Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
  27. If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. It should be slightly too warm to touch comfortably. Overheating the iPhone may ignite the battery.
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. It should be slightly too warm to touch comfortably.
    • Overheating the iPhone may ignite the battery.
    • Flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    • Do not insert your card in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
    • Do not pry against the logic board or you may damage the phone.
    • Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery.
    • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
    • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
  28. Remove the battery from the rear case.
    • Remove the battery from the rear case.
    • If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the the ribbon cable.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
Abschluss
254 weitere Nutzer haben diese Anleitung absolviert.
Paige Reisman
17.624 Reputation
15 Anleitungen geschrieben
Does this effectively negate the waterproof feature of the new iPhones?
Tubby - Antwort
yes , unless it is sealed back with new waterproof tape, which almost no one has yet
Atronx -
iPhone 6 take battery off put new one now not changing at all but saying yes but no going up new battery saying all time 6@.all time
ant2101 - Antwort
Is there any way to put back the waterproof sealing after changing the battery for iPhone 7? Thanks
Steven Tanda Putra - Antwort
I too would like to know this! It's a shame they don't elaborate as such. There is this part here - Display Adhesive iPhone 7 Display Assembly Adhesive which I assume needs to be put on after the screen is taken off but this guide says it's not needed? But for a screen repair it is? Does it get placed on the phone housing or screen? Thanks
blitzn -
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 571
Letzte 7 Tage: 4,177
Letzte 30 Tage: 15,468
Insgesamt: 326,998
