Einleitung
Prereq-only guide for detaching the display assembly en route to other repairs.
Was du brauchst
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
Disconnect the front panel sensor assembly connector from its socket on the logic board.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
