Zum Hauptinhalt wechseln
iPhone 7 Plus LCD Assembly Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. iPhone 7 Plus LCD Assembly Replacement, Releasing the Waterproof Gasket: Schritt 1, Bild 1 von 3 iPhone 7 Plus LCD Assembly Replacement, Releasing the Waterproof Gasket: Schritt 1, Bild 2 von 3 iPhone 7 Plus LCD Assembly Replacement, Releasing the Waterproof Gasket: Schritt 1, Bild 3 von 3
    • Remove the 2x pentelobe screws from the bottom of the phone.
    • Insert your iSesamo tool into the bottom left-hand corner of iPhone 7 Plus and gently pry upwards to release the corner. Heat may be needed to help release the LCD Assembly from the frame.
    • Gently work your iSesamo tool around the outer edges of the device. Be careful not to insert the iSesamo tool too deep into the body of the phone as you may damage internal components that you cannot see.
  2. iPhone 7 Plus LCD Assembly Replacement, Opening the phone: Schritt 2, Bild 1 von 1
    • Gently lift the screen upward and down to release the retention clips from the top portion of the device and swing the assembly open to the right.
    • Notice that there are two sets of plates that must be removed. The upper plate covers the flex cable for the earpiece speaker FPC, and the camera FPC's. The lower plate covers the fingerprint FPC, LCD FPC and the battery connector.
  3. iPhone 7 Plus LCD Assembly Replacement, Removing the FPC plates: Schritt 3, Bild 1 von 3 iPhone 7 Plus LCD Assembly Replacement, Removing the FPC plates: Schritt 3, Bild 2 von 3 iPhone 7 Plus LCD Assembly Replacement, Removing the FPC plates: Schritt 3, Bild 3 von 3
    • Three screws hold the upper FPC plate in place. These are all #000 tri-tip screws.
    • Four screws hold the lower FPC plate in place. These are also #000 tri-tip screws.
  4. iPhone 7 Plus LCD Assembly Replacement, Disconnect the FPC's: Schritt 4, Bild 1 von 3 iPhone 7 Plus LCD Assembly Replacement, Disconnect the FPC's: Schritt 4, Bild 2 von 3 iPhone 7 Plus LCD Assembly Replacement, Disconnect the FPC's: Schritt 4, Bild 3 von 3
    • Using a Nylon Spudger gently pry up the earpiece speaker flex at the top.
    • Disconnect the FPC's at the bottom of the phone that go to the fingerprint sensor FPC and the LCD/Digitizer flex.
    • Remove the LCD Assembly from the housing and prepare to disassembly the LCD Assembly and small parts.
  5. iPhone 7 Plus LCD Assembly Replacement, Remove the earpiece speaker retaining plate: Schritt 5, Bild 1 von 3 iPhone 7 Plus LCD Assembly Replacement, Remove the earpiece speaker retaining plate: Schritt 5, Bild 2 von 3 iPhone 7 Plus LCD Assembly Replacement, Remove the earpiece speaker retaining plate: Schritt 5, Bild 3 von 3
    • Remove the five screws holding the earpiece speaker retaining plate in place. These are #000 phillips head screws.
  6. iPhone 7 Plus LCD Assembly Replacement, Remove the earpiece speaker and FPC.: Schritt 6, Bild 1 von 3 iPhone 7 Plus LCD Assembly Replacement, Remove the earpiece speaker and FPC.: Schritt 6, Bild 2 von 3 iPhone 7 Plus LCD Assembly Replacement, Remove the earpiece speaker and FPC.: Schritt 6, Bild 3 von 3
    • Now that the earpiece speaker retaining plate is removed the earpiece speaker should easily lift off the device.
    • Using the flat end of a nylon spudger gently pry the earpiece speaker FPC away from the assembly. This piece is held on by double sided adhesive but should easily come up with some gentle prying.
  7. iPhone 7 Plus LCD Assembly Replacement, Remove the home button backplate: Schritt 7, Bild 1 von 3 iPhone 7 Plus LCD Assembly Replacement, Remove the home button backplate: Schritt 7, Bild 2 von 3 iPhone 7 Plus LCD Assembly Replacement, Remove the home button backplate: Schritt 7, Bild 3 von 3
    • Using your #000 tri-tip screwdriver remove the four screws holding the home button backplate in place.
  8. iPhone 7 Plus LCD Assembly Replacement, Disconnect and remove the home button: Schritt 8, Bild 1 von 3 iPhone 7 Plus LCD Assembly Replacement, Disconnect and remove the home button: Schritt 8, Bild 2 von 3 iPhone 7 Plus LCD Assembly Replacement, Disconnect and remove the home button: Schritt 8, Bild 3 von 3
    • Using your needle tip tweezers gently pry the home button connector and detach it from the home button flex.
    • Using the flat end of your nylon spudger gently pry the home button away from the back side of the frame.
    • The home button should pass through the hole in the middle of the LCD assembly and fall to your work mat.
    • The home button will not work if it is replaced with an aftermarket part as it is still serialized to the logic board. If you damage this you will have to seek service through apple to restore fingerprint capability. (This will probably result in device replacement.)
  9. iPhone 7 Plus LCD Assembly Replacement, Remove the LCD Back plate: Schritt 9, Bild 1 von 2 iPhone 7 Plus LCD Assembly Replacement, Remove the LCD Back plate: Schritt 9, Bild 2 von 2
    • Remove the five #000 Tri-tip screws and the one #000 Phillips screw that hold the LCD backplate in place.
    • Feed the LCD and Fingerprint sensor cables through the LCD backplate.
Abschluss
21 weitere Nutzer:innen haben diese Anleitung absolviert.
Android Alliance Mitglied von Android Alliance
Community
87 Mitglieder
699 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 12,530
