Einleitung
Prereq for removing the speaker or wi-fi diversity antenna.
Was du brauchst
Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
One 3.2 mm screw
Remove the following three Phillips screws securing the speaker to the rear case:
Two 1.3 mm screws
One 2.0 mm screw
Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
