Zum Hauptinhalt wechseln
Logic Board Connectors
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Logic Board Connectors, Disconnect the logic board: Schritt 1, Bild 1 von 2 Logic Board Connectors, Disconnect the logic board: Schritt 1, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
  2. Logic Board Connectors: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Standoff Screwdriver for iPhones
    $5.49
    Kaufen
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm standoff screw
    • One 3.1 mm Phillips screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  3. Logic Board Connectors: Schritt 3, Bild 1 von 1
    • Remove the rear-facing camera bracket.
  4. Logic Board Connectors: Schritt 4, Bild 1 von 2 Logic Board Connectors: Schritt 4, Bild 2 von 2
    • Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up.
  5. Logic Board Connectors: Schritt 5, Bild 1 von 1
    • Remove the two screws securing the upper cable bracket:
    • One 2.9 mm Phillips screw
    • One 1.3 mm Phillips screw
  6. Logic Board Connectors: Schritt 6, Bild 1 von 1
    • Remove the upper cable bracket.
  7. Logic Board Connectors: Schritt 7, Bild 1 von 2 Logic Board Connectors: Schritt 7, Bild 2 von 2
    • Use the flat end of a spudger to pry the upper cable connector up from its socket.
  8. Logic Board Connectors, Remove the top left antenna component: Schritt 8, Bild 1 von 1
    • Remove the three Phillips 1.3 mm screws securing the top left antenna component.
  9. Logic Board Connectors: Schritt 9, Bild 1 von 1
    • Remove the 1.4 mm Phillips screw securing the antenna component to the top of edge of the case.
  10. Logic Board Connectors: Schritt 10, Bild 1 von 1
    • Remove the antenna component.
  11. Logic Board Connectors, Remove the top left grounding clip: Schritt 11, Bild 1 von 1
    • Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
    • One 1.5 mm Phillips screw
    • One 2.6 mm Phillips screw
  12. Logic Board Connectors: Schritt 12, Bild 1 von 1
    • Remove the grounding clip.
  13. Logic Board Connectors, Unscrew the logic board: Schritt 13, Bild 1 von 1
    • Remove the three screws securing the motherboard:
    • One 1.8 mm Phillips screw
    • One 2.5 mm standoff screw
    • One 2.2 mm standoff screw
  14. Logic Board Connectors: Schritt 14, Bild 1 von 2 Logic Board Connectors: Schritt 14, Bild 2 von 2
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  15. Logic Board Connectors: Schritt 15, Bild 1 von 2 Logic Board Connectors: Schritt 15, Bild 2 von 2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
Abschluss
Arthur Shi
252.690 Reputation
526 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 207
