Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
iPhone back glass is fragile and difficult to repair because it is connected to the housing with welds and glue. Today we are going to introduce a new separator to fix iPhone 8 Plus back glass in an easier and more efficient way.
Einführungsvideo
  1. Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor  via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
  2. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  3. Place iPhone 8 Plus back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold. After 200 seconds of heating, mandril of the machine starts to work.
    • Place iPhone 8 Plus back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
  4. Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 Plus back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
2 weitere Nutzer haben diese Anleitung absolviert.
Phryne
10.181 Reputation
80 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 57
Letzten 7 Tage: 297
Letzten 30 Tage: 1,096
Insgesamt: 1,880
