Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Basic disassembly tutorial for iPhone X.
Einführungsvideo
  1. Press the wake button and volume down button to turn off the phone. Press the wake button and volume down button to turn off the phone.
    • Press the wake button and volume down button to turn off the phone.
  2. Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened. Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened. Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened.
    • Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened.
  3. Undo 5 screws shown in the picture below with a triangle screwdriver Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger. Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
    • Undo 5 screws shown in the picture below with a triangle screwdriver
    • Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
  4. Undo 3 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily Undo 3 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
    • Undo 3 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
  5. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  6. Remove 2 screws and remove the metal plate, release the rear cameras connectors.
    • Remove 2 screws and remove the metal plate, release the rear cameras connectors.
  7. Release all connectors on the motherboard with a spudger Undo 3 screws on the mother board then we can take out the mother board.
    • Release all connectors on the motherboard with a spudger
    • Undo 3 screws on the mother board then we can take out the mother board.
  8. Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine Remove the loud speaker and the taptic engine. Remove the loud speaker and the taptic engine.
    • Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine
    • Remove the loud speaker and the taptic engine.
  9. Pulling out 4 battery adhesives with a tweezers then we can remove the battery. Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
    • Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
  10. Heating the front facing camera with a heat gun will make it easily to be removed Heating the front facing camera with a heat gun will make it easily to be removed
    • Heating the front facing camera with a heat gun will make it easily to be removed
  11. Release 4 screws on the frame shown in the picture Heating the charging port flex  cable then we can remove it easily Heating the charging port flex  cable then we can remove it easily
    • Release 4 screws on the frame shown in the picture
    • Heating the charging port flex cable then we can remove it easily
  12. Release 7 screws on the Wi-Fi flex cable Heating the flex cable with a heat gun make it easier to be removed Heating the flex cable with a heat gun make it easier to be removed
    • Release 7 screws on the Wi-Fi flex cable
    • Heating the flex cable with a heat gun make it easier to be removed
  13. Release 3 screws on the power button Heating the flex cable with a heat gun then it can be removed easily Heating the flex cable with a heat gun then it can be removed easily
    • Release 3 screws on the power button
    • Heating the flex cable with a heat gun then it can be removed easily
Abschluss
92 weitere Nutzer haben diese Anleitung absolviert.
Mandy
9.212 Reputation
9 Anleitungen geschrieben
excellent guide!!!
Andy Lee - Antwort
The iPhone X assemble video: https://youtu.be/E5jyuxgpE_g
Mandy - Antwort
What About the backside ? I heard that when the backside is shattered, it’s almost impossible to repair, because of the glue that holds the backside and parts together ?
Arnoud - Antwort
Hi avdk, we don’t tear down the back glass but we will pay attention to this question. If there is a definite answer, I will reply to you .Thank you.
Mandy -
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 126
Letzten 7 Tage: 789
Letzten 30 Tage: 3,604
Insgesamt: 116,884
