Einleitung
Our high quality repair guide now in english!
Back up all your data before the repair, and touch something metal, like a radiator to get rid of any static charges. The repair is a little more difficult and you need 60-90 minutes.
We recommend these tools for this repair: Pentalobe screwdriver, Phillips screwdriver, Y-type screwdriver, pick, suction cup, spatula, tweezers and spudger. You also need a heat gun to unglue the display.
The Y-type screws have also been called tri-point or tri-wing screws. Tri-point screwdrivers don't fit right and can strip your screw heads. Use a Y-type screwdriver that fits well (Wiha Picofinish Y000).
Was du brauchst
Videoanleitungen
23 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
are we able to repair ourselves or do we need to send to apple directly. unlike other iPhones i have been told that aftermarket parts wont work
James Turner - Antwort
Hola, en dond s puede adquirir la pantalla del iPhone X ??.
Fernando - Antwort
Where can you buy the iphone x screen?
Fernando - Antwort
actually, we do! [verlinktes Produkt fehlt oder ist deaktiviert: IF377-000] we have a nice step by step guide too. iPhone X OLED Display tauschen
Aiden -
replacement of rear camera of iphone x
pankaj - Antwort
