Einleitung
iPhone gets stuck on the Apple logo, which usually means that there is a problem with the operating system or hardware of the phone.
Einführungsvideo
We have an iPhone X motherboard and two flex cables in the box. Here it writes: iPhone X Error 4013.
Check the motherboard first. Nothing goes wrong.
Let’s get the motherboard installed and check. Press the power button. The phone enters into recovery mode automatically.
Judging by this, the motherboard comes with restore failure and therefore the phone cannot enter into the system normally.
Let’s restore the phone and check whether it comes with error 4013.
Restore the phone with 3U Tools. The phone can be restored normally. What’s more, the phone can be normally activated after restore.
Go to Settings>General>About. We can check baseband info here.
We can confirm now that the motherboard is normal. The fault is probably related to other parts.
Get the earpiece speaker and sensor flex cable and front camera flex cable installed. Turn on the phone. The phone is stuck on Apple logo and keeps restarting.
Judging by this, the fault is related to the earpiece speaker and sensor flex cable or the front camera flex cable.
Disconnect the earpiece speaker and sensor flex cable. Press the power button to turn on the phone. The phone turns on normally.
We can confirm now that the fault is related to the earpiece speaker and sensor flex cable.
Check the earpiece speaker and sensor flex cable under the Microscope. The Flood illuminator module is mouldy.
Heat with Hot Air Gun to remove the Flood illuminator module. We can see that its bonding pad is severely corroded.
Clean the bonding pad thoroughly and solder the module back to the bonding pad.
Get the earpiece speaker and sensor flex cable installed and reassemble the phone.
- '''How To Turn An iPhone 11 Pro Into An iPhone 11 Pro Max'''
- '''iPhone 11 Pro Max Cracked Screen Repair'''
- '''How to Fix iPhone 7/7P Home Button Not Working'''
- '''How to Fix iPhone X Face ID Not Working After Screen Replacement'''
- '''How to Fix iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher''''
- iPhone 11 Series Non-Genuine Screen Warning/Important Display Message - 100% Fix
- How To Fix iPhone 8 Stuck on Apple Logo
- Glowing Apple Logo - iPhone 6 / iPhone 6S
- True Tone wiederherstellen nach Bildschirmtausch beim iPhone XS
2 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
Does restoring it this way wipe out data?
You should always backup data before restoring.
viona -
