Was du brauchst
To begin with, it will be necessary to remove the pieces of glass from the old broken camera lens.
Once the glass shards from the camera lens are removed, thoroughly clean the camera bezel (the raised metal part around the camera).
Adhere some double sided tape or two dots of glue on the new iPhone X rear camera cover.
Use tweezers to position the glass lens in its housing.
Lightly press down on the lens for a few seconds to create a good seal.
You can test your rear camera to verify the quality of your photos and videos.
Congratulations ! You have repaired your iPhone XS, the lens is replaced, clean it with a microfiber cloth. You can now take photos and film normally.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
