Einleitung
Hier wird der Austausch des Logic Boards gezeigt.
Bevor du deinen iPod öffnest, sieh nach, ob der Sperrschalter in der Sperrposition steht. Der Schieber sollte ganz rechts stehen, wenn die Vorderseite des iPods zu dir zeigt.
  • Bevor du deinen iPod öffnest, sieh nach, ob der Sperrschalter in der Sperrposition steht. Der Schieber sollte ganz rechts stehen, wenn die Vorderseite des iPods zu dir zeigt.
One word of advice: My cousin opened his vid from the top and accidentally cracked his screen in half. I would suggest to start opening it from the bottom, near the dock connector.
Cyrus - Antwort
I too just cracked the screen in half by starting at the top. The screen is completely shot now. Got a guide for replacing screens? These things are hard to open. Be careful! Have someone hold it while you slowly pry it open.
wittweb - Antwort
I have a cracked screen, starting from the upper right corner. 1/3 ofthe screen is black. Can I fix it?
Phil
koby -
I just replaced a broken screen and battery tonight in my early ipod video 30g. I think you may have not got the audio cable back in correctly or you may need to replace the earphone connector. This site is great and just last week i used ifixit parts to fix my ibook dc in then tonight my ipod. Saved a ton of cash and the service is awesome.
spdmonkey - Antwort
ive just replaced my screen and its working fine, apart from when i switch it on it says i need to connect to itunes, when i do that it says that it needs resetting to factory settings, and when i do that it gets to the end then just says i need to reset it again???? any help please?
qwerty - Antwort
me too hav the same prob.. :D
nadhil muhammed -
very useful
jimixiaozi - Antwort
Replaced my screen that somehow cracked in my bag while it was under the seat in front of me on an airplane. 80GB 5.5g video.
The only thing I'll add is that when I first installed the new screen, I would get all kinds of weird artifacts after putting the case back together. It would be fine with the case open but as soon as pressure was applied it would turn white and go crazy. I looked at the old screen and saw a small white plastic sticker covering the electronics on the old screens ribbon cable, so I peeled it off and put it on the new screen's ribbon cable and everything went back together and worked perfectly. Placing pressure on these components must cause trouble and I guess the sticker disperses the pressure to prevent this. It's like new.
I was really bummed because I have Rockbox running on this thing and no ipods since the 5.5g will run it, and you can't buy those anymore without spending a fortune. Thank you ifixit.com.
gkmeyer - Antwort
i followed all the steps and fix it up by myself ~ haha THX~
swean - Antwort
Quote from hidi00z:
hey, greg29 i have the same situation with my 5th gene iPOD, right now the display it's white and i want to know if you show where i need to put the white sticker or another kind of sticker because the old dispelay i throw it away...thanks,
hidi00z - Antwort
Just finished replacing my battery (30 gb video). Piece of cake! Great information. I would skip steps 7-9, and just replace battery. But I'm no expert....
Gino T - Antwort
I need a little help guys. I have an Ipod 30G video that I plugged into a car charger and now the screen is black with the apple logo. I thought it was the battery that was dead, but I replaced it using your guide(thanks!!) and it's still showing the same thing. Black screen with the apple logo. I tried charging it and it still doesn't do anything. Any ideas what it could be? Thanks.
jer - Antwort
Replaced battery and screen on 30GB video ipod in 90 minutes. In the first 5 minutes the fine tip broke off the removal tool. Later I discovered why....I was prying the front cover off instead of separarting the back cover from the rest of the unit. The front cover tabs are right next to the back cover tabs so be sure you are getting the right one. If done properly I would have saved 30 minutes. I also broke several front cover tabs during removal so good thing I was replacing front cover too! The new front cover did not match up well with the old tabs. I agree with skipping steps 7 - 9 to release the headphone ribbon. I yanked the unit around pretty good getting the front cover back on and no trouble with the headphones. The removal tools were no match for the tape on the back of battery, instead get a very small standard screwdriver to get the battery loose. Trickiest part is the little tab that holds the battery ribbon; when you are putting it back together just push straight down nice and easy with the tip of the small tool and she locks right back in place. The wife had given up on this iPod and get a new 8 GB nano for Christmas...I inherited this one and am quite pleased for $30! iTunes did not pop up when I hooked it to the USB to charge, so I that I will go now and see if there is problem there. Terrific site, thanks for the help.
Jeff - Antwort
Quote from stumped:
I followed all the steps for taking apart my 5th gen Ipod video, replacing the factory battery with a new one. Now my click wheel does not work. I've tried resetting it without success. Any suggestions?
I have exactly the same problem, though I was replacing the headphone jack instead. Nothing appears to be loose and I didn't open the front panel at all.
benthuronyi - Antwort
Quote from jimmora:
Hi - no need to disconnect all those cables, take out the HD, etc. Skip all the way to unscrewing and save the effort of trying to sneak those cables back into place.
well the cables aren't too bad, and you don't want to accidentally tear one of the cables when sliding in the new display-- i'd recommend disconnecting the hard drive, battery and headphone jack before attempting to remove the screen.
iTronics Repair - Antwort
BRILLIANT instructions!
I got software problem after installing new Logic Board. iTunes keeps asking me to restore - I do, but it make no difference. Still can't synch. Anyone else have this problem?
jingofafa - Antwort
Quote from jingofafa:
terry cynright - Antwort
Quote from benthuronyi:
Yes, when I replaced my screen, the click wheel no longer works except I can hold the select & menu buttons and rest my i-pod all day long. that is the only part of the click wheel that now works. Anyone can help all 3 of us out?
dragonlore - Antwort
Quote from terry cynright:
I found out the problem: I used the wrong Logic Board! I have a 5th Gen. 80GB model and needed the 820-1975-A board (instead I installed the 820-1763-A board, which apparently only works for 30 and 60 GB models).
I wish I'd read this sooner: upgrading hard drive from 30 GB to 80 GB
jingofafa - Antwort
I've just replaced the my battery too (30 GB Video). Though it was quite challenging to opening the iPod, it all went smoothly after that; except from a small incident when the small tool broke when attempting to remove the battery from the iPod back. I used the big one instead and it went all fine. I also skipped steps 7-9)
CAUTION: when removing the battery from the iPod back panel, watch-out not to damage the "hold button cable" . The cable is right below the battery, and might be glued to it.
I've connected the iPod to iTunes and everything is reacting fine. My iPod is recharging right now on its cradle :-)
Total handling time: 45 min max.
Thanks to everyone for the tips. Great web site!
gioverking - Antwort
I'd check that the control cable is correctly seated in its ZIF socket. And that the hold switch is not on.
Yishai Sered - Antwort
Quote from Miroslav Djuric:
Nice guide!
It is a nice guide. I happened to have access to a #000 Phillips which I thought worked a little better than a #00. What do you think?
pricemccarty - Antwort
just tryed to replace battery in my i pod but didnt work had to put old battery back in the cable seems to be backwards to the oiginal one now what
saxconstruction - Antwort
Have you tried flipping the battery over?
eggs -
very informative
Mike Chang - Antwort
If a simple diagram of the retaining clips and their locations on the device might be helpful.
RJones - Antwort
The first step was the most difficult for me, as I nearly destroyed the wide opening tool sold by ifixit in the process... after wedging it slightly open, I then grabbed a screwdriver and pulled apart the rest of the iPod. On second thought if I remembered, the putty knife sold here would also help at the very beginning.
Thanks ifixit!
Raj Seshadri - Antwort
Excellent instructions! One suggestion was made to start at the bottom. The first step does show the tool used to start opening at the bottom; so, starting at the top contradicts the first step anyway. Am currently repairing a friends MBP, so have learned a lot about Apple's micro-technology. Patience is certainly a virtue here! : ) Thank you, iFixIt!! Jim W, Panama City, FL
Jim - Antwort
This was a workout! This took me 75+ min.
Very hard to open. Needed butter knife to work the crack begun by iPod opening tool (aka myFinger opening tool when it slips); would take forever with only the tool. Hard to sense when retaining clips release. Please use screws, Apple!
Step 6: Really tricky to slide up the tiny brown connector latch without popping off either it or the tiny white logic board connector. So delicate! I popped off both. Argh! By God's grace, nothing broke, and I got it all back together.
Steps 7-9: Skipped, and glad I did, given #6; just be careful not to over-twist ribbon cable joining case & face..
Step 10: Don't pry out battery looking from same angle as in photo; turn 180 degrees so you can see what's under battery, where to pry or not. I pried with small screwdriver; plastic tool is wrong shape. Apply leverage sensitively; peel headphone ribbon cable off adhesive as you go … slowly. I left some paper on adhesive so cable wouldn't adhere again.
But success. Thanks, iFixit.
rmccord23 - Antwort
I was doing great until I pulled the battery connector off the board. I guess that's game over. Darn! I'm really just trying to rescue someone's music. Does anyone know if there's a way to connect the hard drive to a Mac and access the contents without a functional iPod?
Mike R - Antwort
Well, I found external USB cases on Amazon and eBay for the 1.8" ZIF hard drive, so I know it's possible to use the iPod's drive as an external drive. I just don't know whether it's formatted in a way I can access the music.
Mike R -
Den iPod zu öffnen ist etwas schwierig. Lass dich nicht entmutigen, wenn es nicht gleich beim ersten Mal klappt – manchmal braucht es ein paar Versuche, bis der iPod offen ist.
  • Den iPod zu öffnen ist etwas schwierig. Lass dich nicht entmutigen, wenn es nicht gleich beim ersten Mal klappt – manchmal braucht es ein paar Versuche, bis der iPod offen ist.
  • Öffne den ersten Halteclip auf der Unterseite des iPod mit dem iFixit Opening Tool. Die Erhebung des Werkzeugs sollte auf das Rückgehäuse aus Metall zeigen, um ein Verkratzen der Kunststofffront zu verhindern.
I'm having a lot of difficulty with Step 2. The tool goes in nicely but I can't seem to find the right tool movement that releases the first retainer clip on the bottom. I never get the degree of separation of the back case shown in the photo. When I remove the tool, it just closes back up. Any help is appreciated.
kk - Antwort
Thank you very much. I bought from Spain, it took less than a week to arrive and the replacement was very easy. Peace of cake with your step-by-step guide.
Great job!!
pedrolucena14 - Antwort
Quote from kk:
I also had problems with this and it took some time. The pictures didn't help much with this problem. Honestly, I'm not 100% sure how I got it to work, but I think it is necessary to pry the metal casing outward while working the face upward. Don't give up. I hope this helps.
Just a word of warning to everyone, be careful with Step 2. I was having a hard time opening my iPod (I was using a screwdriver), but when it finally opened I accidentally knocked off some small black thingy on the logic board. I am not too devastated, because it was not working in the first place. But just wanted to warn others.
Gaoez01 - Antwort
i found it useful to get an old credit card to help freeing the case, somehow the opening tool i add was made of really soft plastic - and yes i confirm it s quiet hard to open but afterwards it s snaping back into place quiet easily
oliviermolody - Antwort
So i did it with success - watch out there is 2kind of motherboards -
the audio was gone on mine ( got it replace once by apple (bought in 2006 replace in 2010 failed again in 2011 but no chance to replace it, so i repaired it ...thanks i fixit )
After having given up on getting the case open, I decided to try again. I succeeded by having 2 tools, 1 to keep the bottom open while I used the other to pry open the sides. After that, replacing the hard drive was easy. I did not need to fully separate it by unseating the headphone ribbon jack.
kk - Antwort
I found using another ipod opener tool handy to just hold open the case enough to get a start on the side clips.
paul meegan - Antwort
I've found starting from the TOP or sides to be easier. I could not get the bottom tabs to release until I got the top ones free.
kane298 - Antwort
After hurting my thumb while trying to open the bottom-side I watched some youtube clips to get an idea how it should look like. Instead pry open the case I had much more success by sliding the side of the case up and down with the opening tool until it come loose a litte bit. Then working to the edges and around till a side, top and bottom where open.
Skiko - Antwort
I had a difficult time with this as well. I ended up breaking the supplied iFixit tools, and used a small screwdriver from an eyeglass repair kit to do most of the work. Once three sides are opened it will separate easily, but the first two are tricky. Don't give up.
jpmajor - Antwort
Following the guide is fairly simple. The easiest way to open it, is to slide the tool once you have it in between the metal and the plastic cover. Take your time. A big thanks to ifixit for this guide.
joeyflores37 - Antwort
I could NOT get the opener to do anything starting from the bottom of the iPod. Working off someone else's recommendation, I managed to get a credit card wiggled in there, which gave me the room on the side to get the opener in, and with the slightest twisting motion was able to easily push the case open. Slide down, rotate a little, repeat repeat. Had the case off in about 45 seconds from getting the card into the gap.
dkreidler - Antwort
It was very hard for me to open the case. It took me about forty minutes for this step alone. Try to keep the gap open with a different tool while you work around the edge to a different side. I wished I had a third hand. One to hold the ipod and two to hold the two tools. The top cover bends slightly but this is not a problem, because it's just protective plastic. The clips at the sides also break slightly. Remove the really tiny bend plastic parts because they will be in the way when reinserting the cover (by just pushing the cover back into its place).
nalply - Antwort
To open the case in step 2, think of it more as slightly/gently lifting the metal case away from the clips on the face of the iPod as opposed to pushing in the clips to release them.
Use the pics for reference of where the clips are located.
Imagine popping the case off those clips; the iPod begins to spilt open as you work around the edge.
I had good luck starting on the lower right corner when facing the iPod, then moving around the to the bottom in a clockwise manner.
Mike - Antwort
For me the whole thing started to separate, this guid says the front will separate but says nothing about the little screws holding the front on as well! 2 of the tabs with screws on mine broke at the bottom but thats fine just dont go thinking you can take the front off with just a few tabs!
Russell Wolfe - Antwort
Benutze dieses Photo eines schon OFFENEN iPods als Vorlage. Es hilft dir, die Stellen zu finden, wo die Halterasten angebracht sind: vier an den Seiten, eine oben und zwei unten. So ersparst du für manche Frustration und vermeidest Kratzer in der Kunststoffabdeckung.
  • Benutze dieses Photo eines schon OFFENEN iPods als Vorlage. Es hilft dir, die Stellen zu finden, wo die Halterasten angebracht sind: vier an den Seiten, eine oben und zwei unten. So ersparst du für manche Frustration und vermeidest Kratzer in der Kunststoffabdeckung.
Kommentar hinzufügen
An jeder Seite des iPods befinden sich vier Halterasten. Du kannst die Plastikvorderseite mit einem iPod-Öffnungswerkzeugvon der metallenen Rückseite lösen. Setze das iPod-Öffnungswerkzeugvon an der linken Seite des iPod ein, die Kante des Werkzeuges zeigt dabei in Richtung der metallenen Rückseite. Ein kleines Gitarrenplektrum kann beim Öffnen des iPods sehr nützlich sein. Setze ihn einfach ein und schiebe ihn um den iPod herum, das beschleunigt das Verfahren.
  • An jeder Seite des iPods befinden sich vier Halterasten. Du kannst die Plastikvorderseite mit einem iPod-Öffnungswerkzeugvon der metallenen Rückseite lösen.
  • Setze das iPod-Öffnungswerkzeugvon an der linken Seite des iPod ein, die Kante des Werkzeuges zeigt dabei in Richtung der metallenen Rückseite.
  • Ein kleines Gitarrenplektrum kann beim Öffnen des iPods sehr nützlich sein. Setze ihn einfach ein und schiebe ihn um den iPod herum, das beschleunigt das Verfahren.
  • Vergrößere vorsichtig den entstandenen Spalt, indem du das iPod-Öffnungswerkzeug hin und her wackelst und nach links schiebst.
  • Fahre damit fort, bis die ganze linke Seite des iPods gelöst ist.
  • Du kannst das iPod-Öffnungswerkzeug rechts von der Hold-Taste einsetzen. Sei sehr vorsichtig beim Einsetzen des Werkzeuges, das Display ist sehr zerbrechlich.
Just a note that if you don't have the special opening tools to hand, a couple of guitar picks did the trick for me :-)
Casey Holford - Antwort
I successfully opened my iPod 5G 60GByte with 4 metal guitar picks (these are ultra thin and have a very strong tip to pry in between the plastic front and the metal back/casing)! Make sure you work on the metal back/casing and NOT on the plastic front <= using the (metal) guitar picks pry in between the the plastic front and the metal back/casing with a steep angle (almost 90 degrees with plastic front and hence almost parallel to the sides) downwards so that the sides of the metal back/casing "open up" / bend outwards. The plastic latches of the plastic front than come loose automatically. Once you finished one side the rest follows almost instantly. DO NOT TRY TO PUSH THE PLASTIC LATCHES FROM THE PLASTIC FRONT INWARDS! It took ME less than 10 mins to separate the plastic front from the metal back/casing this way! Thanks for the tip Casey!
Bruno Laurent - Antwort
I found this to be the most difficult step and I don't know if I just used the wrong tools or if I wasn't effectively sliding the tool down the edge to unclip the sides (fyi, I have a ifixit tool kit and used the plastic tools in there). Eventually my ipod gave and separated after about 10-15 of me wrestling with it, but i could see that some of the white plastic bits where the tiny screws are anchored broke in some places. Could've been the fact that it's just old.
John Chang - Antwort
Lasse das iPod-Öffnungswerkzeug entlang der Oberkante des Displays gleiten, so dass dort die Rasten gelöst werden. Jetzt sollte sich die andere Seite des iPods leicht lösen lassen. Wenn nicht, kannst du die rechte Seite des iPods mit dem iPod-Öffnungswerkzeug genau mit der gleichen Methode wie die linke Seite lösen.
  • Lasse das iPod-Öffnungswerkzeug entlang der Oberkante des Displays gleiten, so dass dort die Rasten gelöst werden.
  • Jetzt sollte sich die andere Seite des iPods leicht lösen lassen. Wenn nicht, kannst du die rechte Seite des iPods mit dem iPod-Öffnungswerkzeug genau mit der gleichen Methode wie die linke Seite lösen.
  • Trenne die Vorderseite des iPod etwa zwei Zentimeter weit von der Rückseite.
  • Nun ist das Gehäuse zwar offen, du darfst die beiden Hälften aber noch nicht ganz trennen. Es gibt noch zwei Flachbandkabel, mit denen das Rückteil am restlichen iPod angeschlossen ist.
In case the IPod housing resists the rigidness of the plastic opening tool (tool starts to dismantle slightly) better keep a proper edge on the opening tool and use a very small screwdriver - as sometimes supplied with the display - to very gently squeeze between the housing halves as described to do with the plastic opening tool, so the edge facing rather twards the metal back. The retainer clips just fit tight, no hooks or lightly breaking edges. Once the housing starts to open minimal fingernail force to pull housing parts slightly apart might help, too.
Eric Njoroge - Antwort
Be wary when separating the two halves at the top of the screen. There is only so much flex until your screen will crack which mine did. It was already riddled with dead pixels that made half of it unreadable, but the crack thus required me to get a new screen too. Fun!
Schiebe den braunen Riegel am Verbinder mit einer gebogenen Pinzette oder einem iPod-Öffnungswerkzeug hoch. Er hält  das orangene Flachbandkabel fest. Ziehe an beiden Seiten des Riegels. Der Riegel muss nur etwa 1 - 2 mm angehoben werden, damit das Kabel frei kommt. Ziehe ihn nicht weiter hoch, sonst kommt der weiße Verbinder mit heraus! Hebe nicht zu weit hoch, oder du könntest den Akkuanschluss vom Logic Board herausziehen.
  • Schiebe den braunen Riegel am Verbinder mit einer gebogenen Pinzette oder einem iPod-Öffnungswerkzeug hoch. Er hält das orangene Flachbandkabel fest. Ziehe an beiden Seiten des Riegels. Der Riegel muss nur etwa 1 - 2 mm angehoben werden, damit das Kabel frei kommt. Ziehe ihn nicht weiter hoch, sonst kommt der weiße Verbinder mit heraus!
  • Hebe nicht zu weit hoch, oder du könntest den Akkuanschluss vom Logic Board herausziehen.
  • Achte darauf, den braunen Verbinder gerade nach oben zu schieben. Er ist empfindlich und bricht, falls er aus Versehen zur Seite bewegt wird. Unten hat er Haken, um das Kabel zu halten.
  • Sobald einer der Arme bricht, wird es problematisch, das Akkukabel wieder anzuschließen. Falls einer bricht, schiebe das Kabel in den Schlitz und drücke den braunen Halter herunter, so dass das Kabel nicht herausrutscht.
  • Entferne das Kabel vom Verbinder.
It was the first time I broke open my iPod, and I was a little fuzzy on what was going on with this step. To amplify use the lip of the small opening tool to catch the edge of the cable retainer and gently pull straight up. It should click when released. To get the cable reinserted during reassembly, it was difficult to juggle both halves of the case and have enough slack in the cable to insert it back in the housing. What I used and was very helpful was a surgical hemostat that I used to gently grasp the cable and manuver it back into the housing.
georget - Antwort
f'n great site, i fixed two of my iPods easily, best advice is be incredibly gentle with every step.
bcarlson409 - Antwort
I have had so much bad luck with this step. I stopped using the iPod tool since I do tend to use it as a leverage point and actually break the connector of the board. I now use a paperclip that i bend into a L shape hook and lift the clip. Haven't broken one since...
oldturkey03 - Antwort
This was extremely helpful! My brown connector latch is positioned vertically, so I could not use the ipod tool. The paperclip worked perfectly!
asbell -
The View Huge version of picture is great!!! A diagram of how this fastener works would also be helpful for both disassembly and assembly.
RJones - Antwort
the small connector should not be a prob. i use the apple spudger tool to lift it (to release) and push it down(lock it). it has a definite click as you push down. dont fear the apple!
cheers&aloha
matt
ACMT
matt - Antwort
The iPod opening tool seemed too large for the gap between the case and the connector latch since the thin edge of the tool had broken off during case opening. I used the flat tip of the screwdriver tool on my pocket knife. Be careful if you tilt the case during reassembly. The small brackets/bumpers (blue in the photo) can fall out. If they do, just reorient them according to the photo.
lutorrie - Antwort
A really, really stupid design having this type of connector that you suppose to pry up the tap to release the cable. The white plastic part of the connector is not secured to the logic board at all. So when you pry up on the brown tap u can easily lift the whole thing off. Again, dumb design Apple.
rgarjr - Antwort
I had trouble with the battery clip. As I was trying to leverage the opening tool under the clip I heard a pop. This being the first time I messed with this I thought the latch was open. I could not remove the cable. I tried again with the tool and heard another pop. The cable came out and the rest of the battery replacement was easy, got the new one back in no problem. Problem, the battery clip separated from the logic board when trying to lift the latch :/ Totally uncool, I scoped it out with a magnifying glass and saw that the logic board was damaged and a repair to the clip will be improbable. I am going to try one fix first before, eventually investing in a logic board. It probably won't work but I'll give it a shot.
brillobean - Antwort
I broke the Brown piece ;_; and when I tried to put it back on with a pair of tweezers it flew and I can't find it. is there a place where I can buy a replacement one?
simpr002 - Antwort
You can buy the whole connector from Chinese sellers on eBay for like 7-8 dollars.
rgarjr -
I also broke off the battery connector piece off of the logic board. Any ideas on if I can just replace the connector piece, or if I will have to replace the whole logic board?
mlblossga -
Where you able to find It? I just broke mine and haven't been able to find it. Do you happen to have a link?
Sara Reyes -
Be very careful here.
My configuration was slightly different, the blue tools were too wide to open the connector. I used the tip of a sharp knife and used very little pressure and wiggled upwards the connector from all four sides. Do not push sideways under any circumstances!! I needed ten minutes for this step. I luckily didn't break anything. I was scared when the battery cable finally fell out. I didn't expect that it was just the end of the cable with four visible contacts. To connect the cable of the replacement cable, bend it 90 degrees down so that it goes into the open connector, then carefully push down the connector. It should go down with a very little click. If you are unsure whether you have power, don't close the ipod yet, but connect the ipod with power and wait about 15 minutes.
nalply - Antwort
I don't believe the plastic tool is best suited for this step - it was A LOT easier (and safer) with tweezers to just pull up.
Alison - Antwort
Hello, during replacement, the white plastic part of the connector has separated from the logic board. I tried to plug it again, but it seems that the battery doesn't charge anymore. Is it possible to fix it or do I have to buy a new logic board ?
SPANCRAZI - Antwort
The L bended paper clip in association with a tweezer gave a very good result to unlock the power supply connector. Cheers
marie-jean Colaitis - Antwort
The case tools they're sending now are too wide to fit into the space by the battery ribbon cable connector. Use a bent paperclip or tweezers to pull the connector up to free the cable.
larry - Antwort
Es gibt jetzt noch ein orangenes Flachbandkabel, welches das Vorderteil mit dem Rückteil verbindet.
  • Es gibt jetzt noch ein orangenes Flachbandkabel, welches das Vorderteil mit dem Rückteil verbindet.
  • An dieser Stelle kannst du auch die blauen Gummidämpfer entfernen und austauschen, oder mit dem Trennen des Gehäuses fortfahren.
  • Für den Akkuaustausch ist das vollständige Trennen des Gehäuses nicht notwendig, erleichtert die Arbeit aber doch sehr. Allerdings musst du dazu ein weiteres Kabel lösen, mit dem Risiko, dass du dabei etwas beschädigst.
Am I the only one that got a battery from ifixit and the battery cable was not like the original and much shorter, the ribbon cable was rapped around the other side and about 3/4 inch shorter, and im not sure how to go about the rest of the steps... any advice would be a great help.
speedisgood2004 - Antwort
Quote from speedisgood2004:
oops, just realized you have to make the bends to the cable yourself and unravel the ribbon from how the batter comes shipped.
the brown connector holding the orange battery ribbon cable in place broke off is that bad?
ferny - Antwort
Quote from ferny:
that piece needs to be on their (on the motherboard) so the battery stays connected securely.
I followed all these steps to the letter, charged the new battery and all worked fine for about a day. Now I can't get the iPod to respond to anything. The screen is black, it won't charge, itunes doesn't realize it's plugged in. It is flat out dead and just won't respond to anything. Suggestions?
Sue - Antwort
Quote from Sue:
Mine is acting the same way. I first replaced the hard drive, then the screen, then the battery. Now all it does it says 'do not disconnect'. On my new laptop, it won't let itunes load and stops the o/s from starting if its connnected upon startup. Any ideas?
Exact same thing happened to me. I am trying to assure everything is connected right, but if that does not work I don't know what more I can do. Ideas anyone?
nuskaonline -
I wish I'd done some troubleshooting before I bought a new jack. I got this far in the manual and discovered the connector holding the second ribbon in place had popped open and the ribbon was loose. I reconnected it and problem solved!
If it pops open it looks as if the connector is gone but it isn't. I put the ribbon back in place and gently swept the tool over the spot where the connector is and it went back into place.
Oh well, I have an extra jack if I should ever need it in the future. I know others with the same kind of iPod so I might save the day for someone someday.
RobertS - Antwort
Quote from ferny:
Pat - Antwort
Yes, breaking off the brown hold down lever on either connection is bad. With out that hold down lever the yellow strip that fits into that connection will be loose and cause a bad connection. Sorry
Pat - Antwort
If just replacing the battery, you could skip steps 7,8, and 9.
rsosbe - Antwort
Hebe die Festplatte hoch, damit der Verbinder am Flachbandkabel zur Kopfhörerbuchse sichtbar wird (mit einem gelben Rechteck markiert).
  • Hebe die Festplatte hoch, damit der Verbinder am Flachbandkabel zur Kopfhörerbuchse sichtbar wird (mit einem gelben Rechteck markiert).
  • Wenn die Dämpfer der Festplatte sich lösen, musst du darauf achten, dass beim Einbau die Kerbe, so wie im Bild gezeigt, sitzt.
In my opinion you could skip 7-9. I suppose the only reason to remove the other ribbon cable is to keep from doing it accidentally while pulling the battery off.
dhughes19 - Antwort
I changed the battery yesterday and left out the steps 7 - 9. It's not really necessary to seperate front and back completety.
So you can't break the brown tab. :-)
cguenther - Antwort
I also think that step 7-9 can be skipped.
my new battery is now charging :)
serkaninan - Antwort
[quote|serkaninan]I also think that step 7-9 can be skipped.
If changing the battery, yes, but not if changing the hard drive, as these instr are also a part of. The pic in 7b r.e. bumper tab orientation is very important.
Lavatop - Antwort
I skipped these steps as well but because removing the battery can require some effort, I can see the need to include them. If there was a good way to attach the halves so they act as a single piece, that would be a good alternative to these steps.
RJones - Antwort
This step (and Step 9) is not required to replace/upgrade the HDD!
Hebe die braune  Lasche am Verbinder des Flachbandkabels zur Kopfhörerbuchse vorsichtig mit dem iPod-Öffnungswerkzeug hoch. Sie wird sich um 90° nach oben drehen und gibt so das Flachbandkabel frei. Ziehe das Flachbandkabel zur Kopfhörerbuchse mit den Fingern heraus.
  • Hebe die braune Lasche am Verbinder des Flachbandkabels zur Kopfhörerbuchse vorsichtig mit dem iPod-Öffnungswerkzeug hoch. Sie wird sich um 90° nach oben drehen und gibt so das Flachbandkabel frei.
  • Ziehe das Flachbandkabel zur Kopfhörerbuchse mit den Fingern heraus.
Take great care in lifting this tiny brown tab. It is easy to break. Also, take extra great care when re-installing the cable and setting the tab back down on the cable. The cable slightly "sticks" in place before you place the tab back on it. I cannot stress how much gentleness is key with these miniscule tabs.
euphoria - Antwort
Also to elaborate on euphoria's comment on the brown retaining clip, it does flip back to open, so do be very careful with this clip, but dont freak out when the clip flips back on itself, cause when i did it i thought i had snapped the clip in half... but turns out its fine. Hope this takes a little of the stress out of this delicate process.
Be extra careful pulling up the battery. Mine was stuck down very firmly. Despite trying to be careful, I still managed to tear a ribbon cable.
KFW - Antwort
Quote from euphoria:
Umm if the brown retaining clip breaks, is there anyway to fix it
dreamer92 - Antwort
Is there anyway to get around breakin the tab to connect the headphone cable to the logic board or no
Rob - Antwort
Quote from dreamer92:
I didn't break the tab, but I did lose it. Anyway to replace this? Don't even know what it's called to search for it...
tonyrufkahr - Antwort
I need to know if this is possible to purchase just the retaining clip that connects the battery to the top of the iPod (the delicate clip everyone is warning about).. Mine broke and on top of that i dropped it and lost it... Am i pretty much screwed?
Richard T - Antwort
Yes, secure it with a piece of tape or glue.
Pat - Antwort
I've seen a few comments regarding leaving the headphone ribbon cable attached thus making it unnecessary to lift the hard drive when replacing a battery. I just replaced the battery in my iPod Video 30GB and I started with the intention of not doing that. After going through the process, I'd recommend following the instructions as stated. Those ribbon cables can be fragile and not removing the headphone cable forces you to torque it around while trying to remove the battery, and plus it's difficult to maneuver around it. It's better to remove it so you have more room to work and less possibility of damaging it when the battery finally comes free.
Burnnie Holliday - Antwort
This Step is very tricky!!!!
How to detach is not very hard, but to put it back is a nightmare, please be careful. After spent 1hour fighting with this step I found myself a hard time dealing with a small little tiny golden ribbon, and desperately tried to put the ribbon back to origin. Eventually I successfully ended up this step by placed the ribbon underneath the lock and quickly threw the HD back to press the weight on the ribbon, so it won't be moved. Luckily, It works and Hope this is help u out of the dark, in case u have a same problem as mine.
Piboon Thongtanyong - Antwort
This step (and Step 8) is not required to replace/upgrade the HDD!
Jetzt sollten Vorderteil und Rückteil deines iPod  komplett getrennt sein.
  • Jetzt sollten Vorderteil und Rückteil deines iPod komplett getrennt sein.
Klappe mit einem kleinen iPod-Öffnungswerkzeug das schwarze Scharnier hoch, welches das Flachbandkabel der Festplatte befestigt.  Die Klappe dreht sich um 90° in Richtung des Logic Boards und gibt das Flachbandkabel frei. Halte das Flachbandkabel mit dem Zeigefinger fest und löse die Festplatte vom Kabel.
  • Klappe mit einem kleinen iPod-Öffnungswerkzeug das schwarze Scharnier hoch, welches das Flachbandkabel der Festplatte befestigt. Die Klappe dreht sich um 90° in Richtung des Logic Boards und gibt das Flachbandkabel frei.
  • Halte das Flachbandkabel mit dem Zeigefinger fest und löse die Festplatte vom Kabel.
  • Achte beim Zusammenbau darauf, dass die seitlichen Gummidämpfer an der Festplatte,die eingesetzt wird, angebracht sind. Es gibt eine Anleitung zum Anbringen der Gummidämpfer, die zeigt wie das geht.
  • Wenn nötig musst du auch das blaue Schaumstoffpolsterung von der alten auf die neue Festplatte übertragen.
Notice the small blue bumpers. Mine were not glued and fell out when I moved the hard drive. So when you get to this point take notice of them, and there position. They are not the same. Take them out and set aside in the correct oriented position on your work surface for reinstallation on a later step.
Jeff - Antwort
couldn't get the ribbon out for the hard drive. i just skipped this step and finished. everything works just fine. but be careful when you are removing the SMALL screws. you will have to hold the H. drive while you do this. Make sure that you do not bend the ribbon to much very fragile.
Mic - Antwort
if you're just replacing the front cover step 10 is not necessary. you'll save yourself a lot of time and trouble if you just skip it
jfitzhugh - Antwort
It's absolutely necessary to FIRST release the black hinge holding the hard drive ribbon cable BEFORE trying to remove the the hard drive ribbon cable from the HDD ( <= in case you want e.g. replace/upgrade the HDD)
During re-assembly and/or after having replaced/upgraded the HDD make sure you fix the rubber side bumpers correctly on the sides of the HDD! <= They have top and bottom side which are not identical (the cross section of the rubber side bumpers looks like an "h" on its side)
I attached the blue foam to the bottom of the CF adapter and it made it too thick. It actually bend my front cover. I wrapped the edges of the CF Adapter with electrical tape and removed the foam again.
A K - Antwort
Is the board end of the HDD ZIF 40pin ribbon cable the same on the CE-ATA 10pin cable that comes with the 160GB iPods (every 5th gen, except the 160GB, uses the board to ZIF 40pin cable)?
JW0914 - Antwort
Entferne die drei schwarzen Kreuzschlitzschrauben, welche das Front Panel am Metallrahmen befestigen. Drehe den iPod seitlich um 180°und entferne die drei schwarzen Kreuzschlitzschrauben, die das Front Panel auf der anderen Seite am Metallrahmen befestigen.
  • Entferne die drei schwarzen Kreuzschlitzschrauben, welche das Front Panel am Metallrahmen befestigen.
  • Drehe den iPod seitlich um 180°und entferne die drei schwarzen Kreuzschlitzschrauben, die das Front Panel auf der anderen Seite am Metallrahmen befestigen.
I have some jewlers screwdrivers, but the rail screws are super small, and even my smallest screwdriver barely fit. Don't drop them on the floor or you'll never find them, and when reinstalling, a slightly magnetized screwdriver or tweezers will really help. I used an LED headlamp and reading glasses (even though I don't use them to read) to align the screws.
georget - Antwort
Du wirst ein wenig Widerstand in der Nähe der Mitte des iPods verspüren, da die beiden Teile hier ein wenig verklebt sind. Arbeite dich vorsichtig um den Rand des iPod herum und löse das Frontpanel vom Metallrahmen.
  • Du wirst ein wenig Widerstand in der Nähe der Mitte des iPods verspüren, da die beiden Teile hier ein wenig verklebt sind.
  • Arbeite dich vorsichtig um den Rand des iPod herum und löse das Frontpanel vom Metallrahmen.
  • Hebe den Rahmen (inklusive dem daran angebrachten Display, Logic Board und Klickrad) weg vom Frontpanel.
  • Achte beim Zusammenbau darauf, dass die Taste am Klickrad richtig sitzt, bevor du den Rahmen wieder in das Frontpanel einsetzt.
I have found it helpful to use a piece of scotch tape to hold the center button to the click wheel before removing the front panel.
Fold over an edge to form a tab for easy removal when reinstalling.
d20139 - Antwort
Upon reassembly I struggled for a bit trying to align the center button and getting it to seat properly in the clickwheel hole (the button is completely loose and "floats" in the clickwheel). It seems that it had a preferred orientation and did not rest evenly if it was not replaced in the same position. If I have to disassemble my iPod again, I would make a little marking pen to make a make a mark across the clickwheel and button to note the original position, or better yet, use a couple of pieces of tape to secure the button to the clickwheel before removing the frame from the front case.
georget - Antwort
Das Frontpanel ist frei vom restlichen iPod.
  • Das Frontpanel ist frei vom restlichen iPod.
Watch for the two blue or gray plastic bumpers remenber to put them back if they get loose...
Efrain - Antwort
When he was trying to pull battery cable off the board (top left corner of step 14 picture, white/brown connector) my son broke 2 pins that are still loose. There are 8 pins in two rows and 2 right ones :::: <-- are the ones hanging.Seems to me 4 left are Positive and 4 are right negative battery connectors but don't have big enough magnifier to find out without schematics. Could someone guide me where to either find schematics or bigger picture of pins alone.
Cober - Antwort
Maybe my iPod is different, but my front panel was not connected at all to the rest. All I did was pry off the front panel and replace it. Watch out for the click wheel and make sure it goes back right. All that other stuff didn't apply to me. All I wanted was to change the front cover. Success!
stclair5211 - Antwort
Drehe den iPod so, dass du leichter an die schwarze Plastiklasche heran kommst. Klappe die schwarze Plastiklasche, welche das Flachbandkabel des Displays festhält mit einem kleinen iPod-Öffnungswerkzeug oder deinem Fingernagel hoch. Die Lasche dreht sich um 90° nach oben in Richtung Display und gibt das Kabel frei.
  • Drehe den iPod so, dass du leichter an die schwarze Plastiklasche heran kommst.
  • Klappe die schwarze Plastiklasche, welche das Flachbandkabel des Displays festhält mit einem kleinen iPod-Öffnungswerkzeug oder deinem Fingernagel hoch. Die Lasche dreht sich um 90° nach oben in Richtung Display und gibt das Kabel frei.
  • Verhindere mit dem Finger, dass das Kabel sich hochheben kann. Wackle am Display, so dass es sich vom Rahmen löst. Ziehe es dann vorsichtig nach außen, so dass sich das Flachbandkabel des Displays löst. Du musst das Kabel unter Umständen von den beiden weißen Stiften wegheben, die es nahe der Kante des Rahmens durchstoßen.
I skipped this step and used a small piece of scotch tape to hold the display in place. One less tricky ribbon to reattach!
I also skipped step 16 and left the "fragile" ground wire attached.
ramachetan - Antwort
For those trying to replace a broken screen: for me the replacement screen didn't work at first after reassembling, it lighted up but image was a complete mess. I had to reopen the case and unplug and replug the screen connector quite a few times, jam it left and right a bit, and now it works like a charm.
I just had to find the perfect spot, as surprisingly enough it didn't work when the connector was plugged properly all the way in...
Pek - Antwort
Das Display sollte nun vom restlichen iPod gelöst sein.
  • Das Display sollte nun vom restlichen iPod gelöst sein.
Löse das schwarze Stück Klebeband, das das silberne Erdungsband am Metallrahmen befestigt, ab.
  • Löse das schwarze Stück Klebeband, das das silberne Erdungsband am Metallrahmen befestigt, ab.
  • Das Erdungsband ist sehr empfindlich. Achte darauf, dass du es nicht beschädigst.
This step is quite scary. The logic board (LB) that I received from iFixit had a broken ground tape: I had to peel the whole thing off my old LB, peel the broken one off the "new" LB and stick the old one on the new LB.
Not quite easy, but I did it right.
jimbbo - Antwort
Zitat von jimbbo:
This step is quite scary. The logic board (LB) that I received from iFixit had a broken ground tape: I had to peel the whole thing off my old LB, peel the broken one off the "new" LB and stick the old one on the new LB. Not quite easy, but I did it right.
Hey Jimbo, how can I tell if the ground tape is broken? And what problems occur if the ground tape is broken? Thanks
Scott J - Antwort
It has the same shape as the clicking wheel PLUS that little bit that comes on the frame, which one see on that photo above.
When it's broken, well, it no longer wires the motherboard to the frame.
I'm not quite sure what problem occurs: I haven't tried reassembly my iPod with the broken tape.
jimbbo - Antwort
Zitat von jimbbo:
It has the same shape as the clicking wheel PLUS that little bit that comes on the frame, which one see on that photo above. When it's broken, well, it no longer wires the motherboard to the frame. I'm not quite sure what problem occurs: I haven't tried reassembly my iPod with the broken tape.
Alright thank you. I am wondering because I have been working on getting an iPod to work and the clicker wheel refuses to work. If I hold down the menu/center button to reset, it resets. But when I fire it up normally, it does not recognize me using any of the buttons or trying to scroll with the wheel. I am running out of ideas to trouble shoot and I thought maybe it was that I broke the ground wire when I took it apart the first time.
Scott J - Antwort
the ground tape is an extra part which is glued on top, so since you have to mainly reuse the old part BE REALLY EXTRA CAREFULL and try not to put your finger on the glue or you wont be able to reuse it neither...
Drehe den iPod um und löse die orangene Erdungslasche vom Metallrahmen ab. Achte darauf, dass du nur die dünne  Erdungslasche ablöst, nicht das breitere Flachbandkabel zum Klickrad.
  • Drehe den iPod um und löse die orangene Erdungslasche vom Metallrahmen ab.
  • Achte darauf, dass du nur die dünne Erdungslasche ablöst, nicht das breitere Flachbandkabel zum Klickrad.
  • Schiebe das Logic Board vorsichtig weg vom Metallrahmen. Die Quadrate zeigen dir, wo du drücken kannst. Das Logic Board ist mit dem Metallrahmen leicht verklebt; achte darauf, dass du das Logic Board nicht zu stark verbiegst, indem du zu sehr an einer Stelle drückst.
  • Der Rahmen sollte nun vom Rest des iPods gelöst sein.
I didn't separate the board from the metal frame. I just created enough space at the edge with the click wheel attachment to get it out and put the new one in. When installing the new on I used the small iPod tool to keep the board slightly separated from the frame.
Klappe mit einem kleinen iPod-Öffnungswerkzeug die schwarze Plastiklasche hoch, die das orangene Flachbandkabel zum Klickrad festhält. Die schwarze Lasche dreht sich um 90° nach oben und gibt das Flachbandkabel frei. Löse das Flachbandkabel zum Klickrad mit dem kleinen iPod-Öffnungswerkzeug vom Logic Board. Sei vorsichtig und biege das Kabel nicht zu stark, sonst könnte es beschädigt werden. Löse das Flachbandkabel zum Klickrad aus seinem Verbinder und hebe die ganze Klickrad Einheit vom Logic Board weg.
  • Klappe mit einem kleinen iPod-Öffnungswerkzeug die schwarze Plastiklasche hoch, die das orangene Flachbandkabel zum Klickrad festhält. Die schwarze Lasche dreht sich um 90° nach oben und gibt das Flachbandkabel frei.
  • Löse das Flachbandkabel zum Klickrad mit dem kleinen iPod-Öffnungswerkzeug vom Logic Board. Sei vorsichtig und biege das Kabel nicht zu stark, sonst könnte es beschädigt werden.
  • Löse das Flachbandkabel zum Klickrad aus seinem Verbinder und hebe die ganze Klickrad Einheit vom Logic Board weg.
  • Das Klickrad sollte nun vom Rest des iPods getrennt sein.
When reinstalling the new click wheel mine had no adhesive on the ground wire. I solved by using a small piece of tape that I further trimmed with an exacto knife.
two of the contacts under the click wheel. (Metal circle with black dot aren't clicking. The logic board works besides that. Do I need to replace the whole logic board or can I buy replacement clickers? Also any special tools needed to attach them? Thanks
John Tartamella - Antwort
All these guides tell the user to install the new part and close the iPod. But in the case of click wheel, the guide does not talk about the attaching the ground tab to the metal frame. Also what needs to be done about the ground connector that is mentioned in Step 17?
sam - Antwort
Klappe die braune Plastiklasche, welche das orangene Flachbandkabel der Festplatte sichert, mit einem kleinen iPod Plastiköffnungswerkzeug hoch. Die braune Lasche lässt sich um 90° nach oben drehen und gibt dabei das Flachbandkabel frei. Schiebe das orangene Flachbandkabel gerade aus seinem Verbinder heraus. Das Kabel kann am Logic Board festgeklebt sein. Wenn es nicht gleich herauskommt, dann ziehe es vorsichtig nach oben, um den Kleber zu lösen. Das Logic Board bleibt übrig.
  • Klappe die braune Plastiklasche, welche das orangene Flachbandkabel der Festplatte sichert, mit einem kleinen iPod Plastiköffnungswerkzeug hoch. Die braune Lasche lässt sich um 90° nach oben drehen und gibt dabei das Flachbandkabel frei.
  • Schiebe das orangene Flachbandkabel gerade aus seinem Verbinder heraus. Das Kabel kann am Logic Board festgeklebt sein. Wenn es nicht gleich herauskommt, dann ziehe es vorsichtig nach oben, um den Kleber zu lösen.
  • Das Logic Board bleibt übrig.
Web page images for this step aren't loading into the main window
Steven Sullivan - Antwort
I just finished an additional step, I.e. Replaced a defective dock connector. This involved removing the shield bracket and then carefully cutting the two shield tabs on one side. The opposite side was easy to unsolder. With the shield gone, I heated each of the gold contacts from the top, not touching the board! The heat quickly travels down the contact melting the solder, then you can effortlessly lift off the contact. This is important because you don't want to tear off the solder pads! With the terminals gone the plastic part is loose and just falls off. I then cleaned the pads with a solderwell tip and flux remover. The four holes need to be sucked clean as well. Unfortunately ifixit doesn't carry the connector, so I got one from China via eBay. Took a few weeks to arrive, but original Foxconn part, fit perfectly and installed in 5 minutes. Be sure to use plenty of flux and clean well afterwards! While I had it apart I also replaced the battery (that one I got from iFIxit). Works like a new again!
oliver - Antwort
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
86 weitere Nutzer haben diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer:
100%
Diese Übersetzer helfen uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
Step 20 images aren't loading on this page.....
Step 20 images aren't loading on this web page.....
would i loose my music replacing the LC board on the iPad video?
herbert castro - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 8
Letzte 7 Tage: 53
Letzte 30 Tage: 207
Insgesamt: 113,381
