Zum Hauptinhalt wechseln
Einleitung
No audio? Replace the headphone jack!
  1. Before opening your iPod, ensure that the hold switch is in the locked position.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
  3. Lift the top bezel off of the iPod.
    • Lift the top bezel off of the iPod.
  4. Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
    • Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
  5. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  6. A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
  7. Lift the metal retaining bracket out of the iPod.
    • Lift the metal retaining bracket out of the iPod.
  8. Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
    • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
  9. Remove the two #00 Phillips screws securing the headphone jack to the casing.
    • Remove the two #00 Phillips screws securing the headphone jack to the casing.
  10. Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
    • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
    • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
  11. After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
    • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
  12. Lift the battery off of the logic board and lay it to the side of the iPod.
    • Lift the battery off of the logic board and lay it to the side of the iPod.
  13. Use a spudger to carefully pry up the headphone jack board from the logic board. Be careful to pry up near the connector to prevent unnecessary strain on the board.
    • Use a spudger to carefully pry up the headphone jack board from the logic board. Be careful to pry up near the connector to prevent unnecessary strain on the board.
    • Lift the headphone jack board off of the logic board.
Abschluss
10 weitere Nutzer haben diese Anleitung absolviert.
iRobot
1 Reputation
624 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 24,768
