Einleitung
Use this guide to replace your Nano's front panel assembly. A new front panel assembly will provide a new front glass panel, digitizer, and LCD. The LCD is non-separable from the digitizer.
Was du brauchst
Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
While the front panel is still warm, use the edge of an iPod opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
Lift the front panel assembly from the headphone jack side of the Nano.
Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
Lay the front panel assembly next to the Nano.
Remove the following two screws:
One 2.3 mm Phillips screw
One 2.6 mm shouldered Phillips screw
Use an iPod opening tool to pry the steel shield out of the Nano by its upper right corner.
Remove the steel shield from the Nano.
Use an iPod opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
Remove the front panel assembly, minding its two cables that may get caught. To reassemble, you can use the double-sided tape found here.
119 weitere Nutzer:innen haben diese Anleitung absolviert.
10 Kommentare
Don't forget to include in your repair the adhesive to hold the new screen on. It does not come with the new display. I as unable to find it at iFixit's site but was able to get it here for $10 incl p&p: http://www.badgizmorepair.com/product/ip...
By the time I paid for the screen, opening tool and glue it turned out to be more economical and less hassle to take it to the Apple store (albeit less satisfying than doing it yourself). I suggest you forego the opening tool if you have a good flat blade jewelers screwdriver. A fine temporary fix for not having the correct screen glue is a piece of packing tape. It leaves the iPod open to the elements though, so I highly recommend the correct glue in order to avoid water leaking in around the edge of the screen.
You will also need a very small jewellers or electronics screwdriver for the two screws. I just managed it with an oversized flathead driver.
i had bought these part and succeeded in repair my drown ipod using these guides (luckily only the lcd that didnt work). and it work nicely. thanks
Thanks for the guide. Very useful and easy to follow.
Had some issues with getting the screen off initially, but that was due to the glass along the headphone jack side being cracked into several small little shards (hence the reason for following the guide ;)
Used a replacement screen (incl. toolkit and replacement precut adhesive) that I purchased from ebay for around US$10 (free shipping).
