Einleitung
Diese Anleitung zeigt dir, wie du den Gürtelclip austauschen kannst.
Was du brauchst
Benutze iPod Öffnungswerkzeuge und Metallspatel, um die Rückabdeckung vom Shuffle abzuhebeln. Fange an der Naht in der Nähe des ON/OFF-Schalters an.
Entferne die vier Kreuzschlitzschrauben, mit denen der Gürtelclip auf der Rückseite befestigt ist.
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
9 weitere Personen haben diese Anleitung absolviert.
100%
Hier starten ›
3 Kommentare
I'm gonna try to remove the back cover with minimal prying to reduce cosmetic defects. The plan is to somehow remove the spring loaded clip by pushing out the lever pin, then drilling holes along the edge of the over wherre the 3 little hooks are (In this image, where the right thumb is touching. https://d3nevzfk7ii3be.cloudfront.net/ig...).
It would be great if someone could provide a closer look at where exactly the hooks are so I can position my 1.5mm drill bit better. Also, if you can to figure out how to remove the spring loaded clip mechanism without going through the 4 screws, that'd be awesome! I suspect the pin is held in place by just adhesive, but don't want to risk pushing too hard and causing defects. :(
Is it possible to just push the "pin" through to remove the clip? I want to paint my Ipod and want the clip removed to do so.
is it possible to remove the back cover by pulling the clip outside? i just want not to damage the back cover clips.
