Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two Phillips screws securing the power/volume controls to the rear panel.
    • Remove the two Phillips screws securing the power/volume controls to the rear panel.
  2. Use the tip of a spudger to remove the yellow kapton tape covering the power/volume control ribbon cable.
    • Use the tip of a spudger to remove the yellow kapton tape covering the power/volume control ribbon cable.
  3. Remove the two Phillips screws securing the power/volume controls to the rear panel.
    • Lift the power/volume controls out of the rear panel.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,635
