Zum Hauptinhalt wechseln
iPod Touch 5th Generation Battery Replacement
Was du brauchst
    • Follow this video guide from start to finish and enjoy!
Abschluss
Did you follow all the steps? Yes! Then enjoy!
29 weitere Personen haben diese Anleitung absolviert.
Fix It Planet
1.585 Reputation
3 Anleitungen geschrieben
22 Kommentare
The solder in the video looks like a clear liquid, I’m I missing something. I’m used to solder that looks like wire? Is there something new that is easier to use?
Thanks for putting this up, I’m trying to decide if I can do the soldering and I just want to make sure I know what I’m getting myself into.
Joshua Edwards - Antwort
Sorry for the confusion. That clear liquid is actually flux. The solder has been put on the iron tip prior to soldering the pads. Not much solder is needed but the flux is necessary to help the flow and bonding of the solder.
Fix It Planet - Antwort
What kind of wick do you use?
Nick DeRissio - Antwort
Goot wick. Model: CP - 2015 Width: 2 mm
Fix It Planet -
Could I use an IOpener tool to open the ipod?
Best Songs - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 80
Letzte 30 Tage: 337
Insgesamt: 40,044
