Einleitung
In this disassembly guide the user will learn how to disassemble the iRULU down to the logic board.
Was du brauchst
Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
Using a pair of tweezers, gently unplug connectors A and B from the logic board.
Completely separate the screen and case.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
