Was du brauchst
Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
Insert the new speaker heads where the old speakers were previously.
Now use the soldering iron to solder the leads of the two speakers onto the logic board.
Fast fertig!
Abschluss
