Zum Hauptinhalt wechseln
iRobot Braava 320 Battery Replacement
Was du brauchst
  1. iRobot Braava 320 Battery  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Battery  Replacement: Schritt 2, Bild 1 von 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Battery  Replacement: Schritt 3, Bild 1 von 2 iRobot Braava 320 Battery  Replacement: Schritt 3, Bild 2 von 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S1-G3, Nance Spring 2017 Mitglied von USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
where do I get a new battery from?
j.svetlova - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 4,765
