Einleitung
The deck plate arms help hold the cloth while the Braava is cleaning. If you have trouble placing the cloth or the rubber feet are missing, the deck plate arms need to be replaced. Here are some steps on how to replace them.
Was du brauchst
Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
Gently remove the battery from the tray and disconnect the battery cable.
To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
With the battery removed, rotate your device so the front of it is facing you.
Remove the four 10mm Phillips #2 screws that attach the shell.
Using both hands, hold the device together while you flip it over.
Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
With the shell off, flip the iRobot over and remove the four 10mm Phillips #0 screws holding the deck plate assembly on.
Remove the two 12mm Phillips #0 screws that hold the two springs onto the deck plate assembly.
Remove the two springs by gently lifting them up.
Flip the device over and remove the deck plate assembly cover by lifting it up.
Pull the arms together by lifting them up and to the center.
With the arms together. slide the deck plate up and over the arms until it is fully removed.
With the deck plate off, remove the three 10mm Phillips #2 screw
Be careful when removing the arms, do not lose the springs located under the arms.
