Zum Hauptinhalt wechseln
iRobot Braava 375t Battery Replacement
Was du brauchst
  1. iRobot Braava 375t Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device over upside down and locate the battery panel.
    • The panel has a symbol of a trash can crossed out.
  2. iRobot Braava 375t Battery Replacement: Schritt 2, Bild 1 von 1
    • After locating the panel, locate the screw (should be around the top center).
    • You will need a medium sized flathead screwdriver to loosen the screw.
  3. iRobot Braava 375t Battery Replacement: Schritt 3, Bild 1 von 1
    • Insert the screwdriver and turn counter clockwise (left) to loosen the screw.
    • You may need to apply pressure when turning if the screw is tight.
  4. iRobot Braava 375t Battery Replacement: Schritt 4, Bild 1 von 2 iRobot Braava 375t Battery Replacement: Schritt 4, Bild 2 von 2
    • Once the screw is completely taken off, remove the panel to reveal the battery.
    • The battery will have a wire, follow the wire which will lead to a plastic white clip (pin). Pull the wire clip upwards carefully until the all pins are separated.
    • Use a small screwdriver and wedge the head between the clips if the pins are tight.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
CSU Los Angeles, Team 5-5, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 5-5, Adachi Fall 2022
CSULA-ADACHI-F22S5G5
6 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 155
