Einleitung
The battery gives the iRobot the capability to clean smoothly and efficiently for hours. The device may need a battery replacement due to being warned out over time or overcharging the battery.
Was du brauchst
Once the screw is completely taken off, remove the panel to reveal the battery.
The battery will have a wire, follow the wire which will lead to a plastic white clip (pin). Pull the wire clip upwards carefully until the all pins are separated.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
