Zum Hauptinhalt wechseln
iRobot Braava 375t Fluid Reservoir Replacement
  1. iRobot Braava 375t Fluid Reservoir Replacement, Fluid Reservoir: Schritt 1, Bild 1 von 2 iRobot Braava 375t Fluid Reservoir Replacement, Fluid Reservoir: Schritt 1, Bild 2 von 2
    • Begin by removing the fluid reservoir from the vacuum. To remove, lift upwards from the two buttons on each side.
  2. iRobot Braava 375t Fluid Reservoir Replacement: Schritt 2, Bild 1 von 2 iRobot Braava 375t Fluid Reservoir Replacement: Schritt 2, Bild 2 von 2
    • After removing the fluid reservoir from the device, turn the reservoir upside down and take off the cleaning cloth attached to the velcro strips.
  3. iRobot Braava 375t Fluid Reservoir Replacement: Schritt 3, Bild 1 von 1
    • Inspect the blue cap that is used to insert the cleaning solution. Determine if the rubber is damaged (holes, tears, etc.). Next, check the surrounding plastic area for cracks or deep scratches.
    • To temporarily fix cracks in the surrounding plastic area, apply a sealant like gorilla glue around the inlet of the blue cap. However, it's best to replace the whole reservoir to prevent further damage.
    • If damaged in any way, you can purchase a new reservoir from the iRobot website or similar sites such as Amazon or eBay.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Diego
235 Reputation
2 Anleitungen geschrieben
CSU Los Angeles, Team 5-5, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 5-5, Adachi Fall 2022
CSULA-ADACHI-F22S5G5
6 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 126
