Einleitung
The back shell of the iRobot Braava Jet 240 covers the device’s water tank. Therefore, in order to remove the water tank, the back shell must first be removed. Follow this guide to replace the back shell.
Was du brauchst
Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
Insert a Phillips #1 screwdriver through the screw holes.
Unscrew the two 9.7 mm screws.
