Einleitung
If the wheels on your iRobot Braava Jet 240 need to be replaced, follow this guide.
The wheels of the iRobot Braava Jet 240 are connected to the motor assembly and allow the robot to move around the room to clean. If there is debris caught in the wheels, removing them to clean out debris will be useful. Additionally, if the tire tread is loose or the wheels are otherwise damaged, they should be removed and replaced.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the 11.55 mm screws in the middle of both wheels using the Phillips #1 screwdriver.
Pull the wheel off from the axel, pulling from the top end first so it can slide out at an angle.
3 weitere Nutzer haben diese Anleitung absolviert.
