Einleitung
If your iRobot Braava Jet 240 doesn't charge in the charging cradle, you may need a new battery. Repeated charging can wear out the battery, reducing its charge capacity and making replacement necessary.
If your device is still under warranty, contact iRobot Support for assistance. They should be able to provide a new battery.
Was du brauchst
Pinch one screw and gently lift it.
Alternatively, you can turn the robot upside down to let the battery slide out.
