Zum Hauptinhalt wechseln
iRobot Looj 120 Controller Buttons Replacement
Was du brauchst
  1. iRobot Looj 120 Controller Buttons Replacement, Removing Screws: Schritt 1, Bild 1 von 1
    • Remove the four exterior screws located under controller and on the handle.
    • Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
  2. iRobot Looj 120 Controller Buttons Replacement, Locate Circuitry: Schritt 2, Bild 1 von 1
    • Disconnect circuit board from power leads, and install new circuit board.
  3. iRobot Looj 120 Controller Buttons Replacement, Remove Exterior Screws: Schritt 3, Bild 1 von 1
    • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
    • Remove the five interior screws to access the buttons.
  4. iRobot Looj 120 Controller Buttons Replacement, Accessing the Buttons: Schritt 4, Bild 1 von 1
    • Remove top plate carefully so that none of the electrical components are damaged.
    • Remove the broken button and insert the new button into the mounting hole.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Lucas Otto
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 223
