Zum Hauptinhalt wechseln
Einleitung
This is an easy guide. It should only take a few minutes to complete. The only tool required is Phillips #1 Screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Lay the Roomba upside down on a flat surface. The edge brush is located near the battery pack.
    • Lay the Roomba upside down on a flat surface.
    • The edge brush is located near the battery pack.
  2. Using the Phillips #1 Screwdriver, unscrew the 7.2 mm Phillips #1 screw while holding the edge brush in place.
    • Using the Phillips #1 Screwdriver, unscrew the 7.2 mm Phillips #1 screw while holding the edge brush in place.
  3. Grab the edge brush and lift it up to remove.
    • Grab the edge brush and lift it up to remove.
Abschluss
Samantha Barrett
501 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 17-5, Forte Winter 2014 Mitglied von Cal Poly, Team 17-5, Forte Winter 2014
CPSU-FORTE-W14S17G5
5 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 370
