Einleitung
The battery is quite simple to replace in a Roomba, and only requires removing the side brush and bottom plate before it can be accessed.
Was du brauchst
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Lift and remove the old battery by pulling the tabs on both sides.
Gently replace with a new battery.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
