Zum Hauptinhalt wechseln
iRobot Roomba 551 Brushes Replacement
Was du brauchst
  1. iRobot Roomba 551 Brushes Replacement, Side Brush: Schritt 1, Bild 1 von 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Brushes Replacement: Schritt 2, Bild 1 von 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Brushes Replacement: Schritt 3, Bild 1 von 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Brushes Replacement, Bottom Plate: Schritt 4, Bild 1 von 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Brushes Replacement: Schritt 5, Bild 1 von 2 iRobot Roomba 551 Brushes Replacement: Schritt 5, Bild 2 von 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Brushes Replacement: Schritt 6, Bild 1 von 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Brushes Replacement, Brushes: Schritt 7, Bild 1 von 2 iRobot Roomba 551 Brushes Replacement, Brushes: Schritt 7, Bild 2 von 2
    • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
  8. iRobot Roomba 551 Brushes Replacement: Schritt 8, Bild 1 von 3 iRobot Roomba 551 Brushes Replacement: Schritt 8, Bild 2 von 3 iRobot Roomba 551 Brushes Replacement: Schritt 8, Bild 3 von 3
    • Grab each brush and lift upwards to remove.
Abschluss
John McTigue
331 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 13-14, Regan Winter 2014 Mitglied von Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Mitglieder
19 Anleitungen geschrieben
2 Kommentare
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - Antwort
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 95
Letzte 30 Tage: 475
Insgesamt: 5,841
