Einleitung
Is your Roomba banging its head against the wall? Follow this guide to replace the bumper sensor.
Was du brauchst
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
Flip the bumper over and lift the sensor from its compartment.
You are now free to replace the bumper sensor.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
