Einleitung
If you are looking to replace the side wheel, it is a slightly lengthier process that can be found here.
This is a simple guide to replace the front wheel of the Roomba, which is a simple grab and lift procedure.
  1. Grab the front wheel housing on the bottom of your Roomba and lift to remove.
    • Grab the front wheel housing on the bottom of your Roomba and lift to remove.
  2. Firmly grasp the wheel, and pull to separate from the housing.
    • Firmly grasp the wheel, and pull to separate from the housing.
Abschluss
Deborah Newberry
Mitglied seit 23.01.2014
551 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 13-14, Regan Winter 2014 Mitglied von Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Mitglieder
13 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 645
