Einleitung
This guide explains how to remove the side brush motor from your Roomba.
Was du brauchst
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
