Zum Hauptinhalt wechseln
iRobot Roomba 552 battery Replacement
Was du brauchst
    • to get started, remove the screws under the roomba and remove the secondary brush (yellow brush) and then pull up on the bottom panel.
    • under the castor wheel there is the battery, replace it with a new battery
    • when the battery is installed the robot will play a tone.
    • reseat the bottom panel and screw it back on. screw back on the secondary brush and charge.
Abschluss
congrats! your roomba should be ready to go!
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 164
