Zum Hauptinhalt wechseln
Einleitung
Use this "Prerequisite Only" guide for removing the top silver and black panels for other replacements in the Roomba 560.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the Roomba upside down.
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. Lift the yellow side sweeper, removing it from the device.
    • Lift the yellow side sweeper, removing it from the device.
  3. Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
    • Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
  4. Lift up the back panel to remove it from the device.
    • Lift up the back panel to remove it from the device.
  5. Lift up the yellow battery by pulling up the green tabs on its side. Handle the battery with care.
    • Lift up the yellow battery by pulling up the green tabs on its side.
    • Handle the battery with care.
  6. Rotate the Roomba so the bumper is in front of you.
    • Rotate the Roomba so the bumper is in front of you.
  7. Using the Phillips #1 driver, remove the ten 10 mm screws on the bumper that run along the outer edge of the Roomba.
    • Using the Phillips #1 driver, remove the ten 10 mm screws on the bumper that run along the outer edge of the Roomba.
  8. Lift the thin top cover that holds the bumper in place. Lift the thin top cover that holds the bumper in place.
    • Lift the thin top cover that holds the bumper in place.
  9. Gently lift the device upwards from the bumper to detach these two pieces.
    • Gently lift the device upwards from the bumper to detach these two pieces.
    • There are wires connecting the bumper to the device. Be careful while lifting the device off the bumper as to not damage these wires.
  10. Lift the bumper upwards for easier access. Unscrew the two 5 mm screws that connect the red and white wires to the device using the Phillips JIS #1 driver.
    • Lift the bumper upwards for easier access.
    • Unscrew the two 5 mm screws that connect the red and white wires to the device using the Phillips JIS #1 driver.
    • The sensor can be unplugged from the motherboard so the bumper isn't hanging off the Roomba.
  11. Lift the circular black panel off the lens. Lift the clear lens that is on the other side of the bumper and replace it with a new lens.
    • Lift the circular black panel off the lens.
    • Lift the clear lens that is on the other side of the bumper and replace it with a new lens.
  12. Turn the device over so that it is face up with the vacuum bin in front of you . Press the button of the vacuum bin and pull out the bin from the device.
    • Turn the device over so that it is face up with the vacuum bin in front of you .
    • Press the button of the vacuum bin and pull out the bin from the device.
  13. Use your hands to unhook the snaps  between the silver panel from the black panel located where the vacuum bin was.
    • Use your hands to unhook the snaps between the silver panel from the black panel located where the vacuum bin was.
  14. Using the plastic opening tool, go around the outer edges of the silver panel and unhook the snaps holding it in place. When prying open the top panel from the inner casing, do so gently. Never "force" the top panel to snap off, or you could risk breaking pieces. When prying open the top panel from the inner casing, do so gently. Never "force" the top panel to snap off, or you could risk breaking pieces.
    • Using the plastic opening tool, go around the outer edges of the silver panel and unhook the snaps holding it in place.
    • When prying open the top panel from the inner casing, do so gently. Never "force" the top panel to snap off, or you could risk breaking pieces.
  15. Lift the black handle and use the plastic opening tool to unhook the snaps underneath it. Use the same tool to pry the silver cover from the black central control board.
    • Lift the black handle and use the plastic opening tool to unhook the snaps underneath it.
    • Use the same tool to pry the silver cover from the black central control board.
  16. Lift the silver panel off of the black panel. Lift the silver panel off of the black panel. Lift the silver panel off of the black panel.
    • Lift the silver panel off of the black panel.
  17. Use a Phillips #2 screwdriver to remove the following screws:
    • Use a Phillips #2 screwdriver to remove the following screws:
    • Two 7.5 mm-long screws at either end of the semicircular handle
    • Ten 5 mm-long screws
    • Use a Phillips #1 screwdriver to remove the 5 mm-long screw at the bottom of the control board.
  18. Lift the black panel off the device.
    • Lift the black panel off the device.
    • This will provide access to the motherboard and black circular control panel.
Abschluss
Mairead Blaes
774 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 1-22, Maness Fall 2015 Mitglied von Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 79
