Zum Hauptinhalt wechseln
iRobot Roomba 595 Pet Series Side Brush Motor Replacement
Was du brauchst
  1. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Secondary Brush: Schritt 1, Bild 1 von 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: Schritt 2, Bild 1 von 1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: Schritt 3, Bild 1 von 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: Schritt 3, Bild 2 von 2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Lift the external underside cover accordingly.
  4. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips #0 screwdriver bit to remove the three 15mm screws.
  5. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: Schritt 5, Bild 1 von 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: Schritt 5, Bild 2 von 2
    • Remove the motor from the blue casing.
Abschluss
USF Tampa, Team S10-G5, Thompson Fall 2017 Mitglied von USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
I changed the motor and still does not work.
Jose - Antwort
I changed the motor and still did not work.
Jose - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 712
