Zum Hauptinhalt wechseln
iRobot Roomba 595 Pet Series Wheel Spring Replacement
Was du brauchst
  1. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Secondary Brush: Schritt 1, Bild 1 von 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Wheel Spring Replacement: Schritt 2, Bild 1 von 1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: Schritt 3, Bild 1 von 2 iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: Schritt 3, Bild 2 von 2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Remove the Roomba's external underside.
  4. iRobot Roomba 595 Pet Series Wheel Spring Replacement: Schritt 4, Bild 1 von 1
    • Remove the 15 mm screws with the Phillips #0 screwdriver bit.
  5. iRobot Roomba 595 Pet Series Wheel Spring Replacement: Schritt 5, Bild 1 von 1
    • Once the screws have been taken care of, the wheel component (with the spring inside) can be removed from the main assembly.
  6. iRobot Roomba 595 Pet Series Wheel Spring Replacement: Schritt 6, Bild 1 von 3 iRobot Roomba 595 Pet Series Wheel Spring Replacement: Schritt 6, Bild 2 von 3 iRobot Roomba 595 Pet Series Wheel Spring Replacement: Schritt 6, Bild 3 von 3
    • Remove the two 5mm screws in the component and gently twist the casing until the spring is exposed.
    • Carefully remove the spring from the component assembly as shown
Abschluss
USF Tampa, Team S10-G5, Thompson Fall 2017 Mitglied von USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
3 Mitglieder
5 Anleitungen geschrieben
4 Kommentare
My spring has fallen out and you don’t show where the spring attatches
Rebecca Hubber - Antwort
Where can I get a new spring, mine is missing on the left wheel
emls23 - Antwort
The bracket for the front (white and black) wheel broke. Where can I get a new one?
Kathryn Roberts - Antwort
Where can I get a new spring for right wheel? Do these questions ever get answered?
KMF - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 1,643
