Einleitung
This guide will show you how to remove and replace the battery for your iRobot Roomba 630.
The battery for your Roomba can be found on the bottom side, between the two main wheels and the main brush.
Was du brauchst
Flip over the Roomba and remove the side brush using a PH2 screwdriver.
Remove the 4 screws holding the main bottom plate on and pull the plate away from the body.
Fast fertig!
Ziellinie
