Zum Hauptinhalt wechseln
iRobot Roomba 650 Main Wheel Replacement
Was du brauchst
  1. iRobot Roomba 650 Main Wheel Replacement, Removing the Side Brush: Schritt 1, Bild 1 von 2 iRobot Roomba 650 Main Wheel Replacement, Removing the Side Brush: Schritt 1, Bild 2 von 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Main Wheel Replacement, Bottom Panel Removal: Schritt 2, Bild 1 von 2 iRobot Roomba 650 Main Wheel Replacement, Bottom Panel Removal: Schritt 2, Bild 2 von 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Main Wheel Replacement, Main Wheels: Schritt 3, Bild 1 von 2 iRobot Roomba 650 Main Wheel Replacement, Main Wheels: Schritt 3, Bild 2 von 2
    • Unscrew the six 12mm screws holding the side wheels on using a Phillips 00 screwdriver. There should be 3 on each side.
    • The screws do not come all the way out.
    • Remove the wheels by pulling them out.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Alex Schnorr
646 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 19-7, Maness Winter 2015 Mitglied von Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 20
Insgesamt: 4,473
