Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Sometimes you just want a some new wheels right?! This guide will show you how to replace the wheels that drive your Roomba to become the cleaning machine that it is.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the device over onto its back. Find the side brush, and unscrew the single screw that connects to brush motor  by using the Phillips head #2 screwdriver.
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. Using a Phillips #1 screwdriver, remove the four screws on the back panel. Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. Grab the two pieces of green tape with your thumb and index finger Pull up on the battery in an upwards direction to remove it Pull up on the battery in an upwards direction to remove it
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. These are the contact points on the Roomba for the battery These are the contact points on the battery
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
  5. Remove the three screws with your Phillips head #1, holding the drive wheels in place These three screws will stay in place and won't come out of the plastic These three screws will stay in place and won't come out of the plastic
    • Remove the three screws with your Phillips head #1, holding the drive wheels in place
    • These three screws will stay in place and won't come out of the plastic
  6. Unscrew the actual wheel from the blue plastic holder Pull apart the blue holder to completely remove the wheel Pull apart the blue holder to completely remove the wheel
    • Unscrew the actual wheel from the blue plastic holder
    • Pull apart the blue holder to completely remove the wheel
  7. To go further into the holder to access the programming chips you can unscrew these compartments To go further into the holder to access the programming chips you can unscrew these compartments
    • To go further into the holder to access the programming chips you can unscrew these compartments
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Rhett
1.208 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-20, Maness Winter 2015 Mitglied von Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 5
Letzten 30 Tage: 15
Insgesamt: 1,839
