Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
It is recommended to empty and clean the dust bin often. This will keep your Roomba at its peak performance.
  1. Grasp the back of the Roomba
    • Grasp the back of the Roomba
    • Push the button with your thumb
    • Remove the dust bin by simply pulling out
    • Be careful not to pull to hard as not to have dust/dirt fall out.
  2. To open the gate, push the yellow tab and pull it open Push in the two yellow tabs on the filter and pull it out gently Push in the two yellow tabs on the filter and pull it out gently
    • To open the gate, push the yellow tab and pull it open
    • Push in the two yellow tabs on the filter and pull it out gently
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Matt Davis
1.490 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-20, Maness Winter 2015 Mitglied von Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 1,470
