Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This motor is what keeps that yellow side brush turning, picking up hairs and things dust in those hard to reach places.
Ersatzteile
Keine Ersatzteile angegeben.
  1. First start by removing the two - 6mm screws with your Phillips head #1, that unlock the motor from your Roomba Pull the brush motor out Pull the brush motor out
    • First start by removing the two - 6mm screws with your Phillips head #1, that unlock the motor from your Roomba
    • Pull the brush motor out
  2. Next, with the same head remove the screw holding the plastic housing together Carefully pry the gear box open by placing a flat head screwdriver in the slot This might be difficult and require some shifting of the screwdriver
    • Next, with the same head remove the screw holding the plastic housing together
    • Carefully pry the gear box open by placing a flat head screwdriver in the slot
    • This might be difficult and require some shifting of the screwdriver
  3. Removing these two screws will allow you to access the motor (use the same head as before) Removing these two screws will allow you to access the motor (use the same head as before) Removing these two screws will allow you to access the motor (use the same head as before)
    • Removing these two screws will allow you to access the motor (use the same head as before)
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Matt Davis
1.490 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-20, Maness Winter 2015 Mitglied von Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 6
Insgesamt: 1,377
