Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
You will be removing the yellow side brush and the back panel of your Roomba in order to gain access to other components of your device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the device over onto its back. Find the side brush, and unscrew the single screw that connects to brush motor  by using the Phillips head #2 screwdriver.
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. Using a Phillips #1 screwdriver, remove the four screws on the back panel. Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
Abschluss
Matt Davis
1.490 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-20, Maness Winter 2015 Mitglied von Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 1,333
