Einleitung
If the brushes on your Roomba get stuck or aren’t spinning, you may need to replace them. Follow these steps to replace the brush assembly in your iRobot Roomba 675.
Flip the device over to expose the bottom of the device. Using your hands, press on the two yellow tabs to expose the brush assembly.
Grab the bushes on the side and push to the right and pull up in order to take out the brushes.
From here on out you can clean the brushes and refollow the instructions backwards in order to reinstall the brushes again.
