Zum Hauptinhalt wechseln
iRobot Roomba 690 Drive Wheels Replacement
Was du brauchst
  1. iRobot Roomba 690 Drive Wheels Replacement, Spinning Brush: Schritt 1, Bild 1 von 1
    • Place the Roomba upside down so that the wheels and brushes are facing upward.
  2. iRobot Roomba 690 Drive Wheels Replacement: Schritt 2, Bild 1 von 3 iRobot Roomba 690 Drive Wheels Replacement: Schritt 2, Bild 2 von 3 iRobot Roomba 690 Drive Wheels Replacement: Schritt 2, Bild 3 von 3
    • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
    • Remove the spinning brush from the vacuum.
  3. iRobot Roomba 690 Drive Wheels Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
    • They are labeled with triangular arrows next to them on the cover.
  4. iRobot Roomba 690 Drive Wheels Replacement: Schritt 4, Bild 1 von 1
    • Lift the bottom cover up from the rest of the Roomba.
  5. iRobot Roomba 690 Drive Wheels Replacement: Schritt 5, Bild 1 von 3 iRobot Roomba 690 Drive Wheels Replacement: Schritt 5, Bild 2 von 3 iRobot Roomba 690 Drive Wheels Replacement: Schritt 5, Bild 3 von 3
    • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
  6. iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: Schritt 6, Bild 1 von 2 iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: Schritt 6, Bild 2 von 2
    • Each drive wheel is labeled left and right.
    • Remove three 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
    • Remove the drive wheels from the vacuum.
Abschluss
John Galvin
584 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 1-1, Botvin Spring 2022 Mitglied von UMass Dartmouth, Team 1-1, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 437
