Einleitung
This guide will help you access the filter to be able to replace it for the iRobot Roombas.
Was du brauchst
Rotate the Roomba so that the "R" on top is facing toward you
Press the button at the bottom of the Roomba
Press down on the button and lightly pull until the dustbin is fully removed from the Roomba.
Pull on the yellow tab to open the filter latch.
The dustbin can now be emptied or cleaned.
Flip over the dustbin so that the clear side is facing upward.
Now the green tabs to remove the filter are visible.
This guide will help you replace filter from dustbin.
