Einleitung
The iRobot Roomba 694 comes with a re-chargeable battery and station that it will move to charge in. However, if there is an issue with the battery this is a simple guide on how to replace it.
It is a lithium battery, so if it looks abnormal make sure to take the proper safety precautions.
Was du brauchst
Place the Roomba upside down.
Remove four screws using a Phillips #2 screwdriver.
Remove the bottom cover.
Gently pull the tabs on either side of the battery at the same time to remove the battery from your Roomba.
