Einleitung
As a safety precaution, it is important that you remove the device's power source, the battery, before working on any other component. This will prevent any damage to the other components as well as any harm to you.
Was du brauchst
Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
Remove the plastic plate from the battery box.
Locate the 2 green tabs on the left and right of the big yellow battery.
Grab the tabs with your hands and lift straight upward.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
