Zum Hauptinhalt wechseln
iRobot Roomba 770 Main Wheels Replacement
Was du brauchst
  1. iRobot Roomba 770 Main Wheels Replacement, Battery: Schritt 1, Bild 1 von 2 iRobot Roomba 770 Main Wheels Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
    • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
    • Remove the plastic plate from the battery box.
  2. iRobot Roomba 770 Main Wheels Replacement: Schritt 2, Bild 1 von 2 iRobot Roomba 770 Main Wheels Replacement: Schritt 2, Bild 2 von 2
    • Locate the 2 green tabs on the left and right of the big yellow battery.
    • Grab the tabs with your hands and lift straight upward.
  3. iRobot Roomba 770 Main Wheels Replacement, Side Brush Motor: Schritt 3, Bild 1 von 1
    • Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
    • Remove the brush by pulling upwards.
    • Do not lean directly over the brush when attempting to remove. Removing the brush requires a firm pull and may release suddenly.
  4. iRobot Roomba 770 Main Wheels Replacement: Schritt 4, Bild 1 von 2 iRobot Roomba 770 Main Wheels Replacement: Schritt 4, Bild 2 von 2
    • Using the J1 Philips Screwdriver, remove the two 15.5 mm screws located on the bottom of the plate covering the bottom of the roomba.
    • Lift upwards to remove the bottom plate.
  5. iRobot Roomba 770 Main Wheels Replacement: Schritt 5, Bild 1 von 2 iRobot Roomba 770 Main Wheels Replacement: Schritt 5, Bild 2 von 2
    • Using the J1 Philips Screwdriver, remove the two gold 15.5 mm screws located on the blue plastic module the side brush had previously been attached too.
    • Lift the blue module upwards. The module contains the motor for the side brush.
  6. iRobot Roomba 770 Main Wheels Replacement, Main Wheels: Schritt 6, Bild 1 von 2 iRobot Roomba 770 Main Wheels Replacement, Main Wheels: Schritt 6, Bild 2 von 2
    • Locate the three 15.5 mm screws surrounding each wheel. Use a J1 Philips screw driver to remove these.
    • The screw towards the center for each wheel may be hard to locate and may seem inaccessible. The head of your screw is long enough to reach it.
    • Use your J1 Philips screwdriver to remove these screws.
  7. iRobot Roomba 770 Main Wheels Replacement: Schritt 7, Bild 1 von 2 iRobot Roomba 770 Main Wheels Replacement: Schritt 7, Bild 2 von 2
    • Pull up on the wheels to remove them from the device.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 15-3, Livingston Fall 2016 Mitglied von Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 2,908
