Einleitung
This guide will go over how to replace the motor in your iRobot Roomba 805.
Was du brauchst
Remove the battery panel and the two screws behind the wheels.
Lift up the back panel and remove it from the Roomba.
Remove the three screws holding down the motor. Be aware one requires a tristar bit and the plastic piece under that screw comes free easily.
Once the motor is loose you can pull it up out of the Roomba.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
